jcflyer
09.06.2016, 10:39 PM
Between the short run and tire slipping are you sure you're reaching top speed? Most speed runs take a long long way to reach top speed.
If all you're going by is the speed through the timing lights, I bet that is your problem.
Well no I have taken it out from a rolling start and took it flat out for longer and the numbers are the same..
