Pdelcast
Pdelcast's Avatar
02.16.2017, 05:21 PM
Originally Posted by brainanator View Post
The big Castle BEC PRO has the same arbitrary voltage set points for some reason, while the standard BEC allows you to set it to whatever voltage you want in 0.1V increments. Quite annoying if you ask me.
Sorry guys, it's a hardware limitation in the controllers. For the BEC, we can set arbitrary output voltage because we are using a DAC and current mirror to set the output voltage.
We don't have an additional DAC available for the X controllers, so the adjustments are limited to a 2 bit setting.
Patrick
Patrick del Castillo
President, Principle Engineer
