1/8th X1-CR Project
blackhawk444
1/8th X1-CR Project - 04.09.2006, 06:42 PM
Hello. I am just starting my Jammin X1-CR BL Project! I am going to race against other 1/8th nitro buggies and will probably also bash it quite a bit. So far for electronics I have decided on...
1. Mtronics Genesis Truck esc
2. Feigeo 540C-9L
I have a KO high torque digital servo that I plan on using for steering. For the actual conversion I plan on using a Cold Fusion 1/8th motor mount. Should bolt up nicely. I am going to use Gorilla-Maxx battery straps to hold down the 12 cell NIMH. For now I am going to use my 6 cell GP3300 matched packs. In the future I will most likely upgrade to IB4200's or even Team Orion Platinum LiPo packs. I will definitally post tons of pics of my progress. I should be getting the buggy sometime this week. I still have not order any electronics. Any comments or suggestions will be very appreciated, because I am a 1/8th and BL newb. Thanks! :027:
Sylvester
Sylvester's Avatar
04.09.2006, 06:45 PM
This sounds like a good project, If i were you, you could try a XL motor, more power/runtime, Lipos would surely be good in this buggy, Please do post some pics, i will be watching this thread closely to answer any questions you have and i will try to answer them to the best of my ability.
Losi 8ight e
MMM / Neu 1512 2.5d/f
Thunderpower 5s 5000
blackhawk444
04.09.2006, 06:53 PM
Thanks for the response Sylvester! Now can you explain a bit more about the XL motor? Would would be the advantages/disadvantages? Thanks!
squeeforever
squeeforever's Avatar
04.09.2006, 08:26 PM
advantages: longer runtimes, cooler temperatures, less amp draw thus easier on the esc, and more torque as well as a wider selection of gearing. something you might find helpful with a buggy and no tranny...
disadvantages: none...
Re~Mix
ĄGo Baby Go!
Re~Mix's Avatar
04.09.2006, 08:40 PM
Disadvantages, extra weight and really not needed in a 1/8th buggy.
RC18T FT - Quark Castle Creations Airtronics IB
  Send a message via AIM to Re~Mix
Serum
Serum's Avatar
04.10.2006, 04:37 AM
The 9L is quite hot for such a large wheeled truck?
What gearing does it use on the diffs/spur?
Dafni
Dafni's Avatar
04.10.2006, 04:53 AM
9L is doable on a buggy. I ran a 9L on 14 cells in my buggy once, it's fine on 12/51. Hotter than I like, though, but very fast.
If you run Lipos, I actually find the extra weight of the XL motors an advantage.
If you have money to blow, get a Lehner 1940 or 1950!
coolhandcountry
coolhandcountry's Avatar
04.10.2006, 07:21 AM
I think he is doing the buggy rene. Not the truggy crt.
I think the 10L would be better suited over the 9L. The xl version are more torque with bigger can to get read of the heat. The lehner 19 series are great motors but has a higher price tag.
Peace!
Country
Help support the
Rc-Monster
Buy here
MetalMan
MetalMan's Avatar
04.10.2006, 08:36 AM
Another 1/8 buggy convert! Right now I am running the same motor/controller combo as you are, but with 4s Lipo. My buggy uses a custom slipper clutch that is built from Revo parts, and I chose a spring that's too weak (and it's rated for 20lbs.)! The slipper clutch hums through all of the acceleration. So, I don't think you'll be disappointed with the 540C 9L.
Can't wait to see how yours looks!
Batfish
Batfish's Avatar
04.10.2006, 10:22 AM
blackhawk444,
Are you the same "blackhawk444" from R/C Excitement's forum? I think I saw your post there a couple weeks ago.
Welcome to the forums here at RC-Monster!
I'm working on my OFNA buggy conversion with CCristo now and look forward to seeing yours at the track!
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
blackhawk444
04.10.2006, 02:48 PM
Hey guys. Thanks for the responces! Yea batfish I plan on racing at RCE. Go BL!..lol. So you guys would suggest a 8XL? or a 10L? I would want to run a cooler and more efficient motor. Thanks again.
blackhawk444
04.10.2006, 04:45 PM
Also keep in mind that I will be ONLY running 12 cells or a 4 cell LiPo...Thanks.
boss 302
04.10.2006, 06:21 PM
if i was you i would go with the 8xl incase i ever wanted to go with a higher cell count. the 8xl would run cooler also and have more overall power and potential.
blackhawk444
04.10.2006, 06:49 PM
I really won't go with more cells due to the fact that the "truck" esc can only handle 12. Would a 7XL be better for 12 cells?
Sylvester
Sylvester's Avatar
04.10.2006, 07:03 PM
Yes it would, you'd get better runtimes, and you can gear up to get similar speed to the 9l
Losi 8ight e
