furryninjas
04.21.2006, 03:29 PM
so if i "eventually" dicide to go that route also, can i still use the stock traxxas reciever in the truck, or does that need upgraded also?
maxxdude1234
maxxdude1234's Avatar
04.21.2006, 03:40 PM
Unlikely. The stock TQ3 reciever is 27MHz AM. Most aftermarket radio systems will be either 40MHz or 75MHz, and the spektrum's are 2.4GHz. Plus any aftermarket radio system worth buying will work on FM as opposed to AM. Lastly, most aftermarket radio's are synthesized, whereas the stock radio uses crystals.
So basically, if you plan on buying any half decent radio system the stock reciever won't work.
furryninjas
04.21.2006, 03:45 PM
good to know, thanks maxxdude
