04.22.2006, 04:07 PM
And you gotta get those plugs and wires hot so the solder bonds to the metal. Even if the solder itself melts, it might not bond to the connector/wire unless both are hot enough. Cold solder joint=bad connection=hot connector under high amperage and a little less voltage at your motor.
