sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.24.2006, 12:39 PM
I know of a couple people over on the traxxas board that uses one...for instance candyman does and I think a few others.......basicly you are taking your voltage from your packs and bumping it down to the following....
Output Voltage: 5V jumper in 6V jumper out.
Output Current: Consistant 3Amps. Max 5A 3 Sec.
5V 6V
Std Servo 10pcs 8pcs
High Torque Servo 5pcs 4pcs
Digital Servo 4pcs 3pcs
Output Voltage: 5V or 6V
the max the servo's can handle is 6V....so you should be O.k......but I'll let others chime in also...to ease your mind...
  Send a message via MSN to sjcrss
