neweuser
neweuser's Avatar
04.28.2006, 12:41 PM
Not to hijack, but can you run 20 cells on the 9920? cuz i just bought some...will it get hot?
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
04.28.2006, 01:10 PM
running 20 cells on your 9920 is the max # of cells allowed on your controller.....it can be done...but you run the risk of possibly messing up the controller.....besides running (2) 10 cell packs is alot of weight on a emaxx.
  Send a message via MSN to sjcrss
Bmr4life
04.28.2006, 01:23 PM
20 cells would be 24 volts. I was thinking about running 2 11.1v lipo packs so that would be 22.2v. Would that be running a risk also?
Gustav
Gustav's Avatar
04.28.2006, 02:41 PM
I was running 20 gp2200s on a 9920 for a little while and it didn't get too hot,130F after 10 mins without a fan and no ventilation in the body,but i doubt they hold as much voltage under load as good subCs but they're alot smaller and lighter(4/5th subCs).Also it was a 1300kv motor so little milder on 20 cells.
I wouldn't hesitate to run it on 20 cells personally but put a fan on the controller,that's what i would do with a 10xl,it'll bring that motor to life for sure.
sjcrss
sjcrss's Avatar
04.28.2006, 02:49 PM
heat isn't really the issue with the controllers.......you can allways keep it cool with a fan and good ventilation.....the issue is the voltage spike and or amps that can suddenly go to the controller from the batts.....and it will fry it......like the post I posted earlier...I fried mine on just 12 cells with a amp spike of 123 amps on a 1895 controller......
