Sneeck
RC-Monster Custom
Sneeck's Avatar
05.03.2006, 11:23 AM
I begin to wonder how big of a wooden board you got stuck before your head. How many freagin' time's do I have to tell you that it's
NOT
about voltage, but amperage. For example, if you got 1.20 volt cell's they may aswell give that voltage at only 20 amp's discharge. While other cell's give out 1.175 volt's on 30 amp's discharge, and so on. Voltage doesn't mean the cell is good for your setup and what your going to do with it. If it was a 1/10 onroad racer, you want the most voltage as possible since voltage mean's more rpm, and amp's mean torque aka power. In your case you need amp's to let a 13 turn motor put out enough torque to get it to speed, plus push around a heavy monstertruck with 2 kg's of battery's alone.
The gp3300 are hand's down the BEST cell's as to discharge amp's. Good quality gp's can put out over 100 amp's! at their peak's without failing. Try doing that to unmatched cell's...
And like Gustav said, forget about runtime on your setup. It will be a power rush of 10 minute's top's. It's not a every-day bashing setup you choose to run. It's a uncontrolable speed machine which better has a wide open field to run in.
  Send a message via MSN to Sneeck
Gustav
Gustav's Avatar
05.03.2006, 03:52 PM
I don't know how anyone else feels but i really wasn't bothered about who had the speed record when Promod was doing it,didn't see like a competative thing,more just he was passionate about BL and wanted to show what it could do and go real fast.
Extremexmods,I don't mean to be rude but i've sensed a slightly impertinent attitude at times despite the fact that you wish to use other's knowledge(not least what Promod showed us) to claim '1st place' as you put it.Something about 'standing on the shoulders of giants' (Isaac Newton)springs to mind.Maybe i've misunderstood.
Are you sure you want to spend your money on breaking the record when someone could just whip out a credit card and take it right back?:028:
EDIT;oops cross post,i was carefully wording this for a while,didn't see Serums post.Basically what he said.
