neweuser
neweuser's Avatar
05.21.2006, 12:05 AM
Thank you squee, that's my problem! i got them between the pin to the bearing, AND betweent the shaft and the bearing on the otherside! DUH, i remember reading that! they came with four, so all four should go between the pin and bearing? or the amount needed for a "good" fit but not too tight right? THANKS A MILLION! Yes, they are the prolines! should have gottne the DACE! Oh well, they will work!
