06.05.2006, 09:21 PM
According to the description, it should: http://www.hpiracing.com/index2.htm
Or, a quote:
...With offroad vehicles, the Adjustable Stability Control System helps you concentrate on driving to the next turn as it keeps the vehicle running smooth through obstacles such as rough ruts. Hitting ruts at an angle would normally pull the steering off the intended path and your late counter reactive steering input would have you “flopping all over” when you initially just wanted to go straight. With the assistance from the Adjustable Stability Control System, The steering automatically reacts and keeps you on the straight and narrow, which is the fastest line from point-A to point-B....
