The sudden loss of power is due to having matched packs. This is a result of the batteries and not the motor/controller. The brushless setup would act the same way with the same batteries. 16 cells on the 10L would run stronger, longer than the titan setup. If you used matched battery packs, the performance drop off would be similar as well.
