cart213
cart213's Avatar
06.20.2006, 03:04 PM
Originally Posted by squeeforever
Well I should have said above, but I would rather stick with a Feigao C motor to keep the cost down as well as the fact that it has a built in heat sink.
So what motor would be recommended for 5S lipo?
You can't have both, so which is more important? I guess you could run a 380c-13t, but the motor will be spinning at over 50,000 rpm, so it's not ideal and would get rather hot. Otherwise, if you want 5s, then I again suggest a low kv Lehner Basic motor.
