squeeforever
squeeforever's Avatar
06.21.2006, 11:12 PM
What difference are you referring to? Speed? Runtime? Overall? The main difference is how many winds it is. 9XL= 9 winds.
emaxxmafia
06.23.2006, 10:58 AM
So 7xL is faster than 9xL?
jhautz
jhautz's Avatar
06.23.2006, 03:30 PM
When selecting a motor you need to consider more than just the winds. A system like this needs to be panned out before you start buying. (trust me I learned this the hard/expensive way) Plan out what batteries you will be using. Look at the KV rating for the motor. You should shoot for a motor where the rpm on the batteries you are planning to run is round 75% of the max rpm limit of the motor. Much more than this can cause heat issues in the motor, less and you are not getting all of the potential out of the motor. Now you need to decide what is more important to you, Speed or run time. If you want speed you should select a lower wind motor that will rev a little higher. If you want run time, select a motor with a couple more winds resulting in slightly less speed, but more power and run time.
As for the esc... Don't skimp or you will just wind up buying another one later. If the power rating on the esc is close, my recomendation is to go with the next higher power handleing model. In my opinion this is the bigest mistake that most fist time buyer make. (Myself included) Thinking that they can ''get away with it'' and save a few dollars. Lets face it, its a big investment either way. You might as well do it right the first time and in the long run you will save money.
These brushless systems are fantastic if set up well and frustrating if they are not. It is a critiacle balance between, motor kv rating, motor size, esc Amp rating and the voltage you plan on running, and tie all of this together with the budget you have.
Summary / My recomendation. It sounds like you are planning on running 14cell NiMH, so pick a motor that is on the conservative side of 75% the motors max rpm. You can always add an extra cell or 2 to the system later if you want to pop the speed up. Then get the best/highest amp rating esc that you budget can handle.
These are rules of thumb that I have been learing over the last year or two. Nothing written in stone and there are way more experienced peole on this board than me, but this is my $0.02.
If you don't want the fun/challenge of figureing all of this out and understanding it all, then get the HV. All of the thinking is done for you, its a simple out of the box solution that will bump you up from stock. You woun't be slapping the nitros around with the HV, but it will be a ton of fun.
I know, long winded.... I have that habbit. Sorry.
BTW... I agree with everyone else that has answered this. I love the Quark. Gets my recomendation.
to make it...
or break it...
Silent...But Deadly
