07.17.2006, 12:34 AM
When I programmed mine, I followed the manual to the letter and I didn't have any problems. I read the instructions until I understood the steps so I wouldn't have to try to read it again between each step and possibly lose my spot.
To beep, it has to be hooked to the motor (since that is the part that beeps). Like the manual says, disconnect the drive train (pinion will do) so if you make a mistake and actually aren't in programming, the truck won't take off on you.
