brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
07.21.2006, 07:39 PM
That's what I thought. It may have sent the whole 16 volts through the system though. 8.4 is not that much more than the 6 it usually gets, but 16 will definately blow it.
Also, if the voltage was sent to the reciever and blew it, then went on to the servos, it would most likely have gone to the ESC as well:012:.
As I stated in my first post, I did try a different reciever. Same brand and model, but it was a different receiver. I know that that receiver works too, because it opperates the steering servo in my boat when my EVX is powering it. I also tried using different crystals too.
It seems to me that I have had rather bad luck lately. I just recieved a $70 order from RC-Monster and Tower. I had also just gotten my front CVDs from Ebay. I just found out my now fried steering servo just went out of warrenty:dft002:. I have almost bullet-proofed my drive line with full CVDs, Steel Idler in 1st, Aluminum diff cup in the rear, and 4-screw differential cases. Just when I get it all together, something else breaks:007::035:.
Why me:025:...
Brijar...
Edit: Coolhand, the reciever won't do anything. None of the channels work, no matter what I do. But I'm more worried about the 9920. I've tried using a new and working reciever on it with external BEC supplied from a working EVX, and it won't do anything. I'm going to go try the ESC again with the new Rx and a 6v reciever pack.
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
