Questions
a123 Racing
Questions - 07.24.2006, 01:07 PM
Originally Posted by jhautz
So the box would work on a standad sub c pack?
Hello People,
My name is Brian, I am an applications engineer here at A123 Systems.
Its great to see that you are as excited as we are about these products.
I will be checkin in from time to time so if you have any questions please feel free to post them, if somoene else doesnt get to it before I do then I will gladly answer them.
Questions
1. Q) Can the Hypersonic Turbo be used with other brand batteries?
1. A) We do not reccoemend that the Hypersonic Turbo be used with other batteries. The reason is because our packs are capable of very high discharge amperages (70A continuous on the 2300) with no problem. This is how we are able to make the boost work. As you increase your desired output voltage the Turbo Module draws more amperage out of the pack to acomodate. IF you were to try this with a typical battery it is possible that you could severely damage the pack.
keep the questions rolling,
Power . Safety . Life
Brian
