danverz
07.28.2006, 06:48 PM
I think you got the wrong question out this. It was for standard_63.
Ops :)
I would probably guess close to a 18 cells with out the voltage droping.
20 cells at 1 v is 20 volts and it takes some serious draw for that. I caught the 5s 2p configuration. The 5s 2p is probably just as light as 20 nimhs but more run time for sure.
With my setup and on the road with the road rage tires I saw a peak of 97
Ampere and a peak of 1880 watts. And I'm running 2WD.
I think with the second differential and the with the grip of the front tires,
on the road, I can achieve 120 130 Ampere. It seems to me to be reasonably.
And sure, it's a huge draw :)
Ciao,
Daniele
