MetalMan
MetalMan's Avatar
07.28.2006, 07:00 PM
Hey metal man what kind of run time you get with the 12s motor on what batts and mah and volts etc ?
I'm not sure, to be honest. My Mtroniks Genesis Truck ESC doesn't have a low-voltage cutoff, so I've been careful about the low voltage. It also doesn't seem to like using external LVCs or even UBECs, so I don't want to try it. I'm going to rig up my Mamba Max ESC, but I need some 4mm connectors for the 12s. I run 4s 6600mah 8C. This pack was on sale for only $100 (it's normally ~$160).
