glassdoctor
TEAM FUSION
glassdoctor's Avatar
07.29.2006, 12:28 AM
Well, "runtime" varies a lot depending on what you are actually doing. Do you mean 60 minutes on the track or playing in the street?
There's no way some of the runtime/battery results mentioned here are possible if you are talking about racing. I assume you guys are bashing, right? It is a Stampede, huh? :)
For example, the 35 minutes and 3600mah equates to a mere 7 amps average current draw. Isn't that about right for a mini-t? :D
I would say you need a minimum of 10,000mah to make an hour, and probably more if you actually mean 60 min solid runtime and not messin around.
