Gustav
Gustav's Avatar
08.08.2006, 11:02 AM
Where did you bend the gorilla motor mount?you can use both the small plates for one motor.The traxxas machined motor mount is pretty sturdy,5mm thick i think.The carbon gorilla straps are supposed to be alot stronger than the velcro ones.If your able to fabricate stuff then making a rear support for the motor with the gorilla mount would make it alot stronger.
