squeeforever
squeeforever's Avatar
09.13.2006, 06:10 PM
You will need a LVC (low voltage cutoff) to cut the power to the motor when the pack reaches the minimum voltage so as not to ruin the batteries. You will also need a balancer to balance the cells in the pack while its charging as not to create a large imbalance and ruin the cells.
