Proline 23MM Hexes????
bluonyx
Question Proline 23MM Hexes???? - 09.21.2006, 10:58 PM
Regarding the washers that come with these, do you install two on each, one on each, or don't bother to use them at all?
I noticed when I installed both, they were really hard to get on, and seemed to bind the free spinning a little.
squeeforever
squeeforever's Avatar
09.21.2006, 11:05 PM
Use only as many as necessary.
cemetery gates
09.21.2006, 11:11 PM
i didn't use any, eventually lost them.........
i wish i had used like 2 or something because there is alot of wiggle room..........:eek:
bluonyx
09.21.2006, 11:26 PM
Thanks guys, I'll just use as many as it takes.
Serum
Serum's Avatar
09.22.2006, 01:25 AM
Yeah, untill the bearins are starting to turn bad.. :p
then you need to loose one..
sjcrss
Hyper 7 Erevo Center Diff
sjcrss's Avatar
09.22.2006, 06:33 AM
I have to agree...i noticed they where a little hard to get onto the end of my cvd, but i ended up using all 3 per wheel......and then snugged the 23mm hexes down....but i didn't super crank them....and put new locktite nuts and the end with a litte blue locktite on the threads as well.....also I put new bearings in as well...just check them from time to time and make sure they are still tight
Bl E-REVO
Quark 125b
Castle Creations-Neu 2200kv motor
((2s2p)(4s)
7800mah 7.4v Lipo Pack
E-Revo 1/8 scale Hyper 7 CD
http://www.rc-monster.com/forum/show...1&goto=newpost
  Send a message via MSN to sjcrss
neweuser
neweuser's Avatar
09.22.2006, 09:28 AM
They are suppose to be a tad snug for a perfect fit, they advise being careful with how many you use because if you use to many, it will cause binding and they are hell to get off. You only use as many as needed as stated before. Start with one at a time until the play gets less and less. For me, i had to use two on each.
sjcrss
sjcrss's Avatar
09.22.2006, 10:22 AM
I tried mine with 2 washers, didn't like how it felt, so i put 3 on there, and I like how it feels now....
Bl E-REVO
Quark 125b
((2s2p)(4s)
neweuser
neweuser's Avatar
09.22.2006, 10:28 AM
Just make sure they are not tooooo tight! :)
sjcrss
sjcrss's Avatar
09.22.2006, 10:31 AM
I allready did....everything rolls nice & smooth..thanks for the heads up...
Bl E-REVO
Quark 125b
((2s2p)(4s)
vette1
vette1
vette1's Avatar
10.14.2006, 09:55 AM
I couldn't get the washers on the MIP axles so I did not use them at all. I did notice some play and then one 23mm hub rip off so I had to replace it.:031:
sjcrss
sjcrss's Avatar
10.14.2006, 11:13 AM
shoulda used some washers man......that could have save the 23mm hex
mine were a little snug to get on also....
Bl E-REVO
Quark 125b
((2s2p)(4s)
