more evo ?'s
BlackedOutREVO
more evo ?'s - 09.23.2006, 01:56 AM
what pinion gear do i need to put on a 7xl motor and how many teeth, and how many teeth should my spur have.... 7xl on 16 cells with the stock e maxx spurgears i want the perfect mix of speed, and wheelie acceleration with a good heat level
Serum
Serum's Avatar
09.23.2006, 02:54 AM
singlespeed conversion? and what diffs are you using? 1/8th or stock?
stock spur will be leaving you soon on 16 cells and with a 7XL (it's a rather hot setup)
What controller are you using?
BlackedOutREVO
09.23.2006, 12:28 PM
well i cant find a strobe slipper witch leaves me with the stock e maxx spur gear system, i will have the single speed with a quark 125 amp one or witchever one is 280 bucks i will probably be using the stock diifs for a while but if they are going to be a problem i will upgrade.. but is there anymore places i can get a strobe slipper?
