MetalMan
MetalMan's Avatar
09.23.2006, 10:33 AM
True RC sells a balancer that works with up to 6s. It's the E-Station PB6, and can be found on the chargers page of their website:
http://home.comcast.net/~truerc/Charge/chargers.htm
Are you planning on balancing both 3s packs on one balancer? If you are, you might need to make an adapter harness like I showed in a couple of other threads.
It looks like the PB6 uses the Hyperion/Polyquest taps (balancing connector), which is what Maxamps uses standard on their batteries.
