Go Back   RC-Monster Forums > Questions and Answers > Pre Sales Questions
Pinions
rchippie
rchippie's Avatar
Pinions - 05.08.2005, 03:29 PM
Hi mike!!!
Are your pinions thick were the set screw goes. I was using 32p 5mm bore pinions that i got at FDM, this weekend and striped two of them. Thank's
REAL MEN RUN BRUSHLESS
supermaxx4190
supermaxx4190's Avatar
05.08.2005, 06:37 PM
they are very thick, and use a huge setscrew. they work awesome, im using them with my 10L.
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
05.08.2005, 10:27 PM
I had the pinions made because I couldn't find any that I was happy with. The pinions have a wide tooth area, as well as a thick wall and a beefy 4mm set screw. You won't have any trouble with these pinions. That I can promise!
rchippie
rchippie's Avatar
05.08.2005, 10:54 PM
Thank's mike i'll be ordering some friday when i get paid. Also what size range do you recomend for a 9L on 14 cells with ue diffs ?.
RC-Monster Mike
Site Owner
05.08.2005, 11:10 PM
16,18 or 20 would all work well on that setup. The 18 would be my choice, although the 20 will push you beyond 40 mph, which may be what you are looking for. I usually gear for mid 30s when I race.
rchippie
rchippie's Avatar
05.08.2005, 11:27 PM
What spur would you use with that 18 pinion?. Right know i use a 66 spur.
RC-Monster Mike
Site Owner
05.08.2005, 11:39 PM
I would use a 66 spur as well.
Dafni
Dafni's Avatar
05.10.2005, 02:00 AM
How's the UE diff reduction compared to a stock Maxx diff?
If you run a 18 or 20t to get you close to 40mph or above, you also take off in second gear, right? I assume so, 'cause you told us you lock out first anyway.
Serum
Serum's Avatar
05.10.2005, 07:11 AM
The UE diffs are 43/13
the stock diff are 37/13
rchippie
rchippie's Avatar
05.15.2005, 12:09 AM
Mike i noticed your 32p 5mm bore pinions go up in size by two. 16-18-20 do you have any plans to make 17- 19 tooth pinions ?. If so when ?.
RC-Monster Mike
Site Owner
05.15.2005, 07:42 PM
No immediate plans, but possibly in the future. I have several other things that are taking priority now (like steel idlers, for instance).
Serum
Serum's Avatar
05.16.2005, 03:42 AM
now THAT's great news..
cabking
05.29.2005, 03:18 PM
Can someone tell me the size and thread pattern for the 5mm mod1 pitch pinion setscew please.
I seem to have lost it out of the gear :o
also is the hex size? 1mm
Thanks
Serum
Serum's Avatar
05.29.2005, 04:23 PM
it's an M3 setscrew..
It uses a 1.5mm hex.
cabking
05.29.2005, 04:34 PM
Its smaller than that mate. the 1.5mm is way to big to fit:)
