crazyjr
crazyjr's Avatar
10.02.2006, 06:20 PM
Originally Posted by BrianG
I think I remember reading in the manual that even though you pick NiMH type, if you have ever set the voltage cutoff, it will still be in effect even though you are no longer using Lipos.
That doesn't make sense, if the LVC is in lipo mode even if you pick NIMH it would almost not run due to lower voltages, unless you run way higher voltages to overcome it. Glad i didn't jump on the bandwagon when they came out, I think i'll stick to castle and mamba at any price
