MetalMan
MetalMan's Avatar
10.09.2006, 09:50 AM
Just FYI, you might need a larger pinion than a 14, depending on the diff ratio. I was planning to use 18/46 on my buggy with 4s Lipo and a Neu 1512 2.5D, and the diff ratio is 3.31:1.
A pair of 2s 8000mah packs wouldn't make it too heavy. You might need a bit more shock preload, but it would still be able to push itself just fine.
