neweuser
neweuser's Avatar
10.10.2006, 04:52 PM
Ok, assumming your using the RRP set up. Or 32 pitch, start at 16/66, this gives you a ratio of 4.125. You should be about good there on 12-14 cells. 16 cells may run a tad warm, not sure, but you can always bump it down to 14. I used a 16 with 9920/9xl with mod1 and it ran real cool, but it was only at 3.18, should have been running the 20 ;) on 14 cells!
