10.15.2006, 09:27 PM
Originally Posted by Finnster
That's about the last time I did any programing :)
Format C:? y/n?
I always answer "y" to that prompt, but only if it's on someone else's PC. :)
Admiral: It 14 cells works and 18 not at all, that definitely sounds like something is wrong. Could be a bad solder joint, or a bad cell. If able, you could put a small load on each pack (like 50 ohm resistor or something) and then measure the voltage on each cell seperately.
