Originally Posted by squeeforever
Brian, If you have a Harbor Freight close by (you should), then they will have all the taps and drill bits you need. There cheap sets are like $10 and seem to work just fine. The T-handle is $hitty though...Thats not a problem if you have a good one though.
Actually, I just checked and it seems there is a HF store in DSM. I'll have to go check it out after work. The T-Handle I have is not great either - it's a "Great Plains" brand and I have to tighten it with vice grips to get it tight enough. It does work though.
As to the CF place; I did some more reading and it seems that the finish isn't going to be good enough. There is already some CF on the H8 and it's pretty nice, so I'd like to get some that matches that if at all possible. I'd only be using it for the Rx mount and maybe the ESC mount as well.
