10.21.2006, 10:56 AM
That't not too hot.
This is odd..
I am downloading the movie to check it out.
10.21.2006, 10:58 AM
Hang on..
Try another channel on your receiver. Might be dead.. Happened to me too..
10.21.2006, 10:59 AM
The receiver is ok , itry the receiver with onother esc and works ok...
10.21.2006, 11:02 AM
Did you used an UBEC with the speedcontroller?
Just saw the movie.
10.21.2006, 11:06 AM
no i use internal bec
10.21.2006, 11:20 AM
I would personally use a seperate UBEC with it. have you got one you can test it with? the only option i can think of at this moment is that the BEC is dead.
10.21.2006, 11:24 AM
But the servo steering works ok...
Rene' look the lipo volts...too low for me
10.21.2006, 11:28 AM
NOt good!!!!
10.21.2006, 11:34 AM
In effect the pack it seems swollen...
10.21.2006, 11:37 AM
Thats very bad, i would contact flightpower, sounds like a bad cell to me.
10.21.2006, 11:39 AM
nevertheless I had set up the cut-ff of the quark to 3.0 volts
10.21.2006, 11:52 AM
how come it didn't cut off?
10.21.2006, 11:58 AM
Are you sure you had it set to the correct battery type? If you have it set to NiMH the Quark still lets you set a lipo cut off voltage and you might think you have it set to Lipo.
to make it...
or break it...
Silent...But Deadly
10.21.2006, 11:59 AM
I dont know, but controller broke+battery failure....
AAAAAARRRRRGHHHHH!!!!!!
10.21.2006, 12:13 PM
I set cut-off 3 volts per cells...
