MetalMan
MetalMan's Avatar
10.24.2006, 11:00 PM
You'll need a certain minimum capacity depending on the C rate in order to get a rating of about 60amps continuous. For example, Maxamps 2s 4000mah 15C is rated at 60amps continuous, and would work. You can go higher in capacity from there.
