BitHed
10.30.2006, 10:36 PM
Halloween Update...
...Ok so i re-did the motor mount last night...another late one
...The motor WAS facing forwards at left front but i moved the diff BACK to where it started and top-mounted the motor...That gives me the WHOLE top plate to play with and it will now take a 74mm XL can with room to spare...The top plate is still unsecured towards the center diff and needs some pillars or something...I might just do it with 2mm alloy plate and lighten that with some sexy holes
*Stock top plate is 2.5mm...
I will leave the servo for now...I just want to get the drivetrain all secured first...
...Still lots of room for batteries so that is going to plan...
...Electronics will now be placed at the front of the chassis, opposite side to the steering servo...
...Also the motor plate is only secured to the diff case at the TOP and it is leaning slightly forward so i need to get to in the bottom to straighten it a little bit...
ID:	1920   Click image for larger version
Sower
Sower's Avatar
11.01.2006, 05:01 PM
Looking good - keep the updates coming!
