11.05.2006, 12:42 AM
I really don't know what the error is about then. The connector on the pack is right, the balance adaptor connector is right, maybe the balancer is bad?
Disconnect the balance adaptor cable from the balancer and check the battery voltages there. Maybe there is a break in connection somewhere.
If it's just one more race, maybe you can just charge your packs without balancing. While you probably don't want to do this all the time, at least your packs will be charged for the race. This will give you some time to find the cause of the problem and/or get a replacement balancer.
