kv rating -
11.12.2006, 08:22 PM
is 2779 a good kv for 12-16 cells?
and can some one tell me how to id the power diff. i know the lower the kv the more cells u can run but is this rules an always?
11.12.2006, 08:48 PM
For most motors, you want to keep the total rpms at or below between 30,000-35,000 rpm for best efficiency. So, you just divide 35000 (max rpm) by the kv to get the desired voltage. Then you divide that by 1.2 for NiMH cells or 3.7 for Lithium cells.
For 16 cells, that would be over 53k - a bit on the high side. I'd stick to right about 12 cells if it were me.
11.13.2006, 02:41 AM
12-16 cells is a rather large difference. though the 8XL would be a good overall choice. (kv-wise, depending on the vehicle?)
11.13.2006, 06:20 AM
its for a buggy im doing i think iam going with the 12 cells
11.13.2006, 01:38 PM
For 12 cells it's okay. But 14/16 is pushing it..
What motor is it?
11.13.2006, 05:24 PM
it the Nemesis Blue 6xl i may try the Nemesis BLUE XLT- 4 but i cant find any info on the kv rating
11.13.2006, 05:27 PM
stay away from that FD fraud.. It's most likely a 6XL..
why not get a proper KV type?
11.13.2006, 05:39 PM
is he?:mad:1 i know the Nemesis BLUE is the same as the Feigao/Wanderer i just wanted it in blue:027: also on a completely diff note do u guyz think 3mm carbonfiber chassis is to thin?
11.13.2006, 08:20 PM
y do the Nemesis and the Wanderer 6xl have diff kv rating? they are the same right?
11.13.2006, 08:45 PM
They should be the same. Maybe one is rated under load and the other rated no load?
11.16.2006, 12:26 AM
i emailed fdm to find out the kv of the xlt4 for my buggy and he said he couldnt tell me it all he said is that the rpm range is 45,000-64,000 RPM thats all so i dont know if i will try it or not i know u guyz dont like his stuff but hes stuff gets some good speed
11.16.2006, 01:47 AM
... but he doesn't list the temperatures of the components after a full run with the vehicles going at those speeds. If he can't give you a specific (or approximate) kv for the motor, then he is withholding information, which is just about one of the worst things to do to a customer (IMO).
11.16.2006, 02:47 AM
Shoot for yourself, but those motors are hot.... the fact that he doesn't want to share his 'secret' receipt tells me enough.
it's just a hot XL motor, no wonder it's fast...
11.16.2006, 11:19 AM
i c what u mean
05.16.2007, 02:13 PM
I wish i did stay away from him.
The worst thing was is tha i had already found RC-monster but not its forum and didn't think to see what people thought of his service and liked his conversions so chose to buy from him. BIG MISTAKE.
I bought a XLT1 and a BK 9920 speed control from him
he didn't tell me the Kv of the motor as mentioned before on th eforum and he sent me a BK marine 9920 speed control instead which is useless for cars and is now just gathering dust.
This wasn't necessarily his fault but i had to pay customs about £45.00 ($90) first which just made it even worse.
