jhautz
jhautz's Avatar
11.28.2006, 04:00 AM
whith the quark 125+heatsink I run my 9xl in my emaxx at 66/22 (3.0 gear ratio) with standard maxx diff ratio and 5.8inch tires in heavy grass fields with no heat problems. I use 66/26 (2.54 gear ratio) on pavement with 5.25" tires.
You should be able to run 18/51(2.84 gear ratio) on the beach without issue. Depending on your tire size and diff ratios. The 51/16 (3.18 ratio) is conservative IMO.
9xl is the right motor for 5s. 8xl on 5s will run hot just from the high rpm.
to make it...
or break it...
Silent...But Deadly
