zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.09.2006, 01:38 PM
Well, first, what system will you be powering it with? an maxx?
And yes, the pros and cons are right, if you want to call them that.
peronally, i would rather have one really good pack, than say, two or three 'decent' batteries. The A123's are simply much better, some other benefits:
-ultra durable, both in physical abuse, and performance abuse (shorting, over-charge, over discharge)
-they will last and last if treated only adequate
-again, 15 minute charge time, you can charge them up as soon as you run out
They deliver almost full Ah rating, they have the flattest discharge voltage curve of any battery (very nice), and you also don't have to worry about them getting too hot, or anything, they are fundamentally safe batteries. They will not burn, explode, or be permanently damaged if discharged/charged to quickly.
consider this
