jhautz
jhautz's Avatar
12.10.2006, 04:00 PM
That is pretty tight. Have you got a test run on it yet. I have seen them in a crawler but not in a buggy or speed truck.
No haven't tested it yet. Its not even close to being finished.
As far as the motor goes, its a little different than a typical outrunner. It has a 40K rpm capability due to some kind of wiring that makes it act like a 4 pole motor to the controller allowing the high rpm from an outrunner that is normally limited by the controller frequency capability. I am not sure what to expect from this thing, but being the optimist that I am... I am hoping for all the torque of an outrunner, with the rpm of an inrunner. (the best of both worlds) I'm sure there will be some sort of compromise, I'm just not sure what it will be.
Bench testing w/ a mamba max it runns nice. Also bench tested it on a QUark125, and also ran good. I am going to test it on a BK controller also, but I expect that it will not run very well. The BK's dont handle the motors with more than 2 poles well.
to make it...
or break it...
Silent...But Deadly
