12.16.2006, 02:55 PM
First, did you bind the receiver to the transmitter? You can tell by simply working the steering servo. If that works, then the transmitter is bound. If not, then you need to get this working first.
If that is fine, make sure your EPA is set to 100% or more on the throttle channel. Set your throttle trim to "0". Then, just follow the instructions in the MM ESC manual. You may want to check to make sure the throttle channel is not reversed.
