GorillaMaxx360
GorillaMaxx360's Avatar
12.21.2006, 10:58 PM
the reason for the high gearing is because i want to achieve 50ish buy being able to use the slipperntial, 4s lipo, and a 7XL. i was going to run HB diffs but i swiched to maximizer because of the lower ratio (2.8 v.s 3.something for HB diffs) for this lower ratio allows me to achieve my disired speeds without changing from 4s to 5s. Also i wanted to gear it so high (if high means up on pinion) so i could get it to 48 but if i used a 14t pinion per say i would be doing 30ish. So basically i geared up so i could get the most out of the motor with out having to go up on cell count. does this make sense
