GorillaMaxx360
GorillaMaxx360's Avatar
12.21.2006, 11:03 PM
squee my question for you will there be heating issues/run pretty hot with my setup and using a 20t pinion because it is so high(the pinion). Or no matter what diffs i go with (hb or maxx standard) the pinion being 20t should not overheat the motor is this what your saying. is it hard on the motor to gear it like i previously said (maximizer diffs, slipperential, 36t spur, and 20t pinion) is this bad for the motor thanks
