BlackedOutREVO
12.24.2006, 05:35 PM
well ur batteries are just about the most crappy pack u could have, so get some ib or gp batts and there will be a big difference
and then to reach youre insane speed u will have to use a 3 cell lipo and the 5700kv mm and then u should be good
12.24.2006, 05:49 PM
@fiero_silva: I think I also posted a response over at the Traxxas forums.
You can gear down by going with a smaller pinion or larger spur. If you divide the tooth count of the spur by the pinion, you get a ratio. Larger ratios are lower geared and lower ratios are geared taller.
According to my calculations, you should be able to reach ~50mph in first gear and 66mph in second with 6 cells, and no tire ballooning. So, something is definitely wrong.
Generally, it is advisable to use a lower KV motor and higher voltage. The current requirement would be less. Some vehicles are difficult to use anything more than 6 cells, but since the Jato is custom, it shouldn't be difficult to use 3s-4s.
And yes, battery quality is a big factor in performance. So, get high quality GP cells or good lipos capable of ~100A continuous for best results.
fiero_silva
12.24.2006, 07:03 PM
Where are you getting those numbers from? Using the link in your sig, I'm getting 55mph as top speed in 2nd gear with my current setup. I think the only thing that could be different is tire diameter... I don't have my truck in front of me, so I used 3.5".... What are you using?
12.24.2006, 08:02 PM
4.2" tire. Maybe that's not right...
