Procharged5.0
Procharged5.0's Avatar
01.03.2007, 03:21 PM
btw, if you're using a low watt drawfrom the packs you can use their "turbo" pack which allows you to select the nominal voltage. They are limited though. Probably around 300watt draw. You'll need to inquire about that I don't have the ratings handy.
