I'm using a Schulze 18.97 controller with a Plettenberg MAXXimum and I can't get my E-Maxx to go into reverse. I have the micro switch set to the proper position, according to the instructions. Any ideas??
I'm looking at the manual know it says the # 3 switch should in the # 1 postion. You might want to try doing the programing with power off. You may also want to check your radio for proper settings.
keep the gas on at least 75% of backwards/brake for at least 2-3 seconds. It will reverse, somehow.. Eventually.. when it feels like reversing.. if you ask it polite..
Well, I figured it out! I had to adjust the Brake End-Point Adjustment (EPA) to 75% and now it works. Duh! I should've known that it was something simple like that!:D Everything is good to go now.
