Batfish
Batfish's Avatar
06.13.2005, 09:14 AM
I can offer a suggestion for the programming error you're getting now.
I had a very similar situation when I was first programming my 12012 with my M8. It turned out that I needed to disable ABS on the radio in order to program the controller properly. I received the error beeps nearly every time I tried to enter programming mode with ABS on.
Hope that helps, and I'm sure someone more knowledgeable will weigh in as well.
Joe
