glassdoctor
TEAM FUSION
glassdoctor's Avatar
01.16.2007, 02:45 PM
Originally Posted by neweuser
I belive so, but was that the correct one other than that particular detail? I think I'll get the plug type too. What do you mean by "Break"?
Also, am looking for a tool that can make it so I can "set" the screw and am not finding it?
Break... as in having the tap snap in two... and leaving half of it stuck in the hole. Not fun. :)
Go easy when using the tap tools... if it jams up don't force it too much or you might break it. When it gets stuck tight, back it off a turn and try agian, or back it all they way out if it still jams up.
Not sure exactly what tool you are referring to.. have you check mcmaster-carr?
