pinolelst
02.01.2007, 01:15 AM
This is where I'm at.Waiting on the feigao 540c 8xl to get here and the new body to finish it off.I made the battery holder from carbon fiber 80/20 cloth laid up in 4 layers with a piece of depron foam sandwiched between the 2nd and 3rd layers on the bottom so I'd have some depth to cut holes for the mud guard nuts.I used a block of foam as the form and wrapped it with cling wrap to act as a release film and wrapped the outside tightly with the same stuff to give it at least a 1/2 baked finish.
The battery strap bolts are holding it to the deck as well as velcro on the inboard side to act as a sort of leveler.
I also epoxied together some carbon ribbon I had laying around to make the BEC/receiver mount to get them up off the deck.I need to find one of those antenna expansion nut doohickies that fit in a drilled hole or fabricate something for the antenna as well.
thanks
pinolelst
ID:	2316   Click image for larger version
ID:	2317   Click image for larger version
jhautz
jhautz's Avatar
02.01.2007, 02:02 AM
I like it. It looks good. With that CF battery tray and the layout it looks alot like mine. Looking forward to finding out how it runs. Keep us posted. What kind of lipó are you going to use?
to make it...
or break it...
Silent...But Deadly
