Batfish
Batfish's Avatar
06.20.2005, 10:06 PM
The absolute best way is to buy the expensive crimping tool from Anderson. I, however, use a crimper I got at Home Depot and just make sure I take my time to do a good job.
That article will show you what a good crimping job should look like with the connector. Regardless of the tool you use, you should strive for that look.
Once I have the connector crimped, I put the housing opening-up on a table and place a precision flat-head screwdriver on the back end of the connector to force it down into the housing. I just keep pushing down until it clicks into place. They also sell an "insertion tool", but my method works well for me.
Joe
Electronics run on smoke... if you let the smoke out, they stop working.
