01.29.2007, 12:52 PM
Hope this pic posts ok. It provides additional details. PICTURE SHOWS STANDARD MODEL
BMW M Power!
01.31.2007, 11:38 PM
Wow that looks AWESOME. :004: I'll be your first customer (maybe a tester? :D - hint hint lol :eek: :005:)
I think this will be the ticket for me since my RR spur has been slipping like hell. The point between locked and too much slip is literally just a 3/32 of a turn or so, and the worst part is the nut loosens and such - making it a pain in the arse to keep it constant.
You have a price range yet?
01.31.2007, 11:42 PM
Very rough estimate of $55-60 standard and $90 PRO model w/DFL gears & Delrin Spur. The single speed versions will be $7-10 less.
BMW M Power!
01.31.2007, 11:56 PM
Whoa...thats a great price. The RR setups are nearly 40 and these are by FAR better...
PS. Need a tester? lol
RC-Monster jumper
02.05.2007, 09:41 AM
i might need one of these without the input shaft.
for a project of mine.
when will it be done hank?
thanks, mike.
02.05.2007, 10:52 AM
Mike,
If you need just the slipper you can buy that from any LHS that stocks traxxas parts. It is a REVO3.3 spec slipper. I have a limited quantity on hand for the initial product release and would prefer to keep them for the complete slipper kits. If you need a spur, then let me know what you need (Material & tooth count) and I should be ableto help you out there.
RC-Monster jumper
02.05.2007, 11:23 AM
ok. thanks.
i'll shall see what i need soon.
BMW M Power!
02.06.2007, 10:29 PM
Procharged - any idea of when the initial release will be?
02.06.2007, 11:59 PM
Late February. Waiting on the next batch of shafts & delrin spurs. All other parts are in stock including packaging.
Order -
02.08.2007, 06:53 PM
Keep me posted , I'm looking forward to their availability... See whether you can get a 10t Mod pinion with 1/8 bore..
Thanks
02.08.2007, 06:59 PM
I'll get back to you on the pinion. I don't think it's a problem.
02.09.2007, 05:54 PM
Kiwi,
I can supply that 10T, Mod1, 1/8" bore pinion for $24
Perhaps Mike could make one for you for less. Have you asked him?
btw...hopefully slipper kits will be available thru RC-M as well.
02.09.2007, 05:59 PM
Hank; Mike has got mod1 10t 6mm hole gears, i think it would be cheaper to make a 3.2>6mm adapter.
02.14.2007, 03:32 PM
will any Spur bigger than 52T fit?
Radek
V4 D8 - RX8, XERUN 4168SD
*EX-10 Eurus*
02.14.2007, 04:38 PM
Yes, however 53T Delrin is the largest I have available at this time. I have no plans for anything larger. Most have asked me for smaller spurs in the 48 - 50T range.
