Trakpower 700 watts? not really.. they claim to stay above 3V on 50C bursts. that would make a 2S pack a 1400watt burstpack.. Have not seen any graphs confirming this, but this was told by flightpower.
i mean 700 watt continu. maybe more.
i have a truck with 6" tires, 3.31/1 diffs and 2.36/1 tranny.
spur is 50, pinions from 17~22 fit.
that leave's me with a range of 22.99/1~17.76/1.
I'm thinking I sould try a 5s pack of these new cells and drop the gearing in my buggy/truggy. I'm curious to see how much the runtime is affected.
At 4s, the 5000mah may barely make the 20 min mark, but maybe I could drop the mah per minute just a bit with a lower gear/high volt. I'm not sure if the gearing will offset the potenial of higher current from the higher voltage.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
yeah, there are numerous shops in belgium that sell flightpower.
but does this mean they will also have trakpower?
i would want 2 packs and the balancer.
i do know a shop in holland does the trakpower packs and balancer.
